I'm trying to author my own DVD using Adobe Encore. I've only used Nero 6 before but think that it has very limited functions and barely supports any file format (atleast not the ones I have tried).
But in Adobe encore I cannot add my .AVI file. When I try to "Add Asset.." it says that the resolution has to be either 720*576 or 704*576. Does anybody know how I can change the resolution of my file, either by adding black bars or something else without stretching it to look all weird. I tried to use Open Video Converter I think but damn did I get bad quality and stretch for that matter aswell.
I also used OGMDemux and Virtual Dub Mod to first transform a OGM file to the AVI. Maybe I can use Virtual Dub Mod for this purpose aswell cause I got perfect quality out of that program.
I live in Sweden so I supose choosing PAL in Encore is the right thing?!Yes, I'm noob.
Thx
There was an earlier post discussing this short-coming in Encore - no one seemed to come up with an answer although one suggested fiddleing the headers.
https://www.videohelp.com/forum/viewtopic.php?t=215553
But since you are using VirtualDubMod to convert OGM to AVI you may as well use the 'resize' filter to get it to the compliant size. -
Thx for the tip but I can't seem to find the Rezise filter in Virtual Dub Mod! Where is it?
//Andy -
It's under 'Video' -> 'Filters' -> 'Add' then double click on 'resize'.
Yeah that actually worked... But if I, in the future, wouldn't have the time to do all this stuff. Is there some other DVD burning program that doesn't care about the resolution??
Thx alot for your help -
Well it's the DVD Standard that dictates what a program will accept, but it seems that ENCORE will only accept a sub-set, generally as long as your video matches any one of the following specs most DVD authoring programs will accept it. If your resolution doesn't match one of these then you will need to re-size it.
Just trial some of the programs available in the tools section, I personally use TMPGencDVDAuthor and some of the Ulead products.PAL Video:
Up to 9.8 Mbps* (9800 kbps*) MPEG2 video
Up to 1.856 Mbps (1856 kbps) MPEG1 video
720 x 576 pixels MPEG2 (Called Full-D1)
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
16:9 Anamorphic (only supported by 720x576)
NTSC Video:
720 x 480 pixels MPEG2 (Called Full-D1)
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
16:9 Anamorphic (only supported by 720x480)
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 15:04 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 09:46 -
Can't change the file size
By spiro murray in forum ffmpegX general discussionReplies: 3Last Post: 11th Mar 2009, 22:48 -
How to change picture size
By hilario in forum Video ConversionReplies: 18Last Post: 24th Mar 2008, 09:04 -
A Device To Change The Picture-Setting's
By grom in forum DVB / IPTVReplies: 5Last Post: 18th Oct 2007, 12:06
Yes, I'm noob.
