I'm using a Compaq EVO D310V pc with a pre-installed dvd rom. I have downloaded some software to determine the status of the region and it seems to be locked to region2. What can i do to get my drive to become region free>? my e-mail address is : swirlproductions@absamail.co.za
Hello,
Try dvd genie. Also look up the model number for your dvd drive and enter it here:
https://www.videohelp.com/dvdhacks
Good luck
If your drive is Region locked, you'll need to:
1) flash the firmware with a region free (RPC-1) version to unlock the drive. http://forum.rpc1.org/portal.php
2) Install a program to let your dvd software player play the different regions, I use DVD Region Killer but there are others. https://www.videohelp.com/tools?toolsearch=DVD+Region+Killer&Submit=Search&s=&orderby=N...res=&listuser=
This will allow you to play any region without locking up.
WARNING; Read instructions on firmware flashing and use the correct firmware for your drive, as interupted or incorrect flashing can kill your drive leaving you with an expensive door stop!
Happy flashing -
thanks for the help! I am checking it now. I do not know the manufacturer of my dvd rom drive, as it was pre-installed, it shows up as a generic dvd drive? The drive name etc. is something like jsl-blah blah blah?
If your using Windows XP right click on My Computer click Properties, click Hardware tab, Click Device Manager, then expand DVD/CD-ROM Drives. This will show your drives model name
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
LG HB806TGW Region Free Hack
By saf1916 in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2011, 09:25 -
region free hack?
By adriansherman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Apr 2011, 00:19 -
Region free hack - unlock
By gf0012 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Feb 2008, 17:43 -
region free hack for LG BH100
By gmarkaus in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Jul 2007, 08:09
