  1. I've got an AVI movie file, that when I tried to convert to MPG file to put on DVD with different conversion programs. It will stop in different frames. Eg, if I used TMPGENC to convert the avi file to Mpg, it would stop at 1hour into the conversion process every time. Then if I used Ulead Mediastudio pro to convert to MPG file, it would stop at 50minutes into the conversion process everytime. What exactly is the problem with this AVI file???? Is there anything to fix up the avi file before converting into MPG file.
    Can I use virtualDub to do a frame serve to fix up errors in the file??
    What is the best way to fix this avi file to enable smooth conversion into MPG file by various programs????
