Is there a simple way with TMEG to chop the sides of a video as to make it anamorphic ratio (2.11 to 1) while maintaning object ratio. I can make it appear in anamorphic ratio, but its just the original video fit into an anamorphic space.
well thats what u want though right?
in tmgpenc, you have 2 res sizes-
1 is the output res which is what video sits inside
2 is the res that the vid is played back in
your output res will usually be 352x240 if u dl movies or dvd ripping at 704x480.
in the advanced tab, you set in the input res you want.
when played back, the input res is what u see played back
the output res is just what makes it fit on your tv
WMV Aspect Ratio Changing?
By Crazyj32 in forum Video ConversionReplies: 11Last Post: 10th Aug 2014, 07:53 -
MP4Box - changing the aspect ratio?
By emilroh in forum EditingReplies: 2Last Post: 3rd Nov 2010, 09:41 -
Changing aspect ratio for WMV?
By vato76 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2010, 10:27 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 13:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 06:40
