it worked! and now i want to delete the rendered files and move on to rendering the 2nd part. I am going to make 2 or 3 DVDs of the 1st project before i do this. But say down the road someone else wants a copy of one of these, will i be able to put the DVD-r in my DVD-rom drive, copy and paste the contents to the hardrive, and then write that to a blank DVD-r? or will i need the project saved and captured video files?
i need to free up some HD space to move on!
- Mike
You dont need to save the project files,just rip the files to your hdd as an iso image and burn with DVD Decrypter,just make sure you check the burned dvd first for mistakes with an program such as dvdinfopro.
No to both questions. A movie DVD is not the same as a data DVD.Originally Posted by 3hitsaday
What burning software are you using? Most if not all DVD burning programs will allow you to make a copy of your authored DVD. -
i'm using Pinnacle Studio 9's burning process.
so basically once i have the finished product i want and a few xtra copies, go ahead and delete the files and move on? -
Unless I'm missing something, I'd have to disagree on both counts.Originally Posted by jyn999
Here's how I understand it:
1. 3hitsaday has authored a DVD from source files.
2. This DVD, I'm presuming, is a bog-standard DVD-R with a VIDEO_TS and an AUDIO_TS folder.
3. There are VOB, IFO and BUP files in the VIDEO_TS folder.
4. Unless he's totally loaded, there'll be no encryption.
So, it is possible to just copy the folders to the hard drive at a future date and then burn those to a different DVD-R, or even DVD+R should he wish.
I know, I've done it.
And, because of that, it's OK to delete the rendered files if he's sure they won't be needed again.
@ 3hitsaday - P.S. Congratulations on your first DVD. Good feeling eh?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
@jyn999, you are wrong. There is no problems doing a 'copy and paste' of the files from a DVDr to your HD and the writing back to DVDr. The only issue would be making sure to use the correct filesystem on the new disk (UDF/ISO).Originally Posted by jyn999
Doing ISO Read then ISO Write with DVDDecrypter as johns0 suggested is probably the simplest and most foolproof way.
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 14:16 -
DVD with a home made video of a wedding can not get it work on dvd player
By kyrieanddave in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 12:03 -
Any DVD or BR burners made in Japan?
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Dec 2008, 14:38 -
Verbatim DVD+R DL - Made In India?
By zippy2k2 in forum MediaReplies: 27Last Post: 2nd Aug 2007, 12:56 -
How can I rip a badly made DVD?
By semmel in forum DVD RippingReplies: 6Last Post: 14th Jul 2007, 11:34
