Ok, I got a new Toshiba DVD-ROM that burns dvd-r's. I installed it worked fine. Than i realized that once i put in my dvd-rom my cd-rom doesnt work. I can dissconect the IDE cable on the dvd and leave it on the cd that way the CDrom works. Weird. I know its not the power supply not big enough becasue i have both connected, and they both open.
On rare occasion when i get both showing in "My Computer" when u put a CD in the CDROm it freezes up. Even Weirder. But if Dissconect The DVDrom, the CDrom works. Now what the heck is going on??
Thanks in Advance!![]()
You should look at the jumper settings on both drives.
They may both be set to master or slave.
One needs to be on master and the other on slave.
You should also put both burners on different ide channels. -
You can leave both optical drives on the IDE channel, one must be set as master and one as slave though. As you made no indication that the cd-rom is a burner, I would make the cd-rom the slave and dvd burner the master.
The Cdrom is a burner and i have the dvd set to master and the Cdrom to slave, but still doesnt work....
Thanks for your help though.....
like on my DELL there is a limit up to 4 IDE devices at one time. floppy, HD, CDRW, DVDRW but when i hook up a 2nd harddrive then my floppy is disabled. ...i think
The floppy controller is separate from the IDE controllers... you shouldn't lose your floppy because you have 4 IDE devices.Originally Posted by rubberman
On any computer, you are limited to 4 IDE devices. That is not Dell Specific.Originally Posted by rubberman
The only way to have more IDE devices is to have another IDE controller card.
buttons on JVC XV-N50 dont work
By schlep in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2012, 23:59 -
Trouble with audio from mobile. Used to work fine. Dont know what happned.
By UmmAddan in forum AudioReplies: 5Last Post: 6th Jan 2010, 10:13 -
Restored videos dont work!
By BVG in forum Video Streaming DownloadingReplies: 5Last Post: 7th Jan 2009, 20:50 -
DVD menus and RTMs dont work right
By shashgo in forum Authoring (DVD)Replies: 0Last Post: 20th Dec 2008, 13:54 -
Remotes dont work under MCE 2005
By Annex in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Jun 2007, 08:30
