I am finding strange problems on certain DVD players. The opening
credits (text on a black background)on my DVD will appear blank, with
just a blank screen. After the opening credits, the video plays
without a problem.
Then, at the end of the video, I have stills with text at the bottom
of the screen, followed by rolling credits. As soon as the first
still with text appears, the video stops, but audio keeps playing.
Eventually, the rolling credits appear for a few seconds but then also
stop.
This only happens on some players...on others, it's fine. The video
was captured from a DV camera, and edited with Premiere 6.5. I added
the credits with Premiere also. The final DVD was made with DVD
Workshop, latest version.
I used TMPGENC to do the encoding. Tried different methods too, all
with same results (Variable Bitrate, 6K Constant Bitrate, 7950
Constant Bitrate) Can anyone suggest a way to correct this problem, or
tell me why it might be happening? Again, on most DVD players there
is no problem, but I do see the problem on others, such as an APEX.
It somehow seems to be related to the text/credits, which is odd.
maybe problem with your burning or media as it could be the begining and end are also begining and end on the disk ..
another thing it could be is that the bit rate is dropping to low - which some dvd players seem to have a problem with .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I've tested on very short clips which barely take up any room on the DVD, so I am doubting it has anything to do with the media.
Also, I tried both constant bit rate and variable bit rate tests, and the problem occurs with both. So, I'd think it couldn't be too low a bit rate either. Thanks for the suggestions, though. -
Following up on this, I encoded the file using Adobe MPEG Encoder with Premiere 6.5, using VBR and same type of settings that I had used in TMPGEnc. This time, the DVD played perfectly on all DVD players that I tried, including the one that did not work previously with the TMPGEnc encoded file.
I'd prefer to use TMPGEnc in the future, but how can I figure out what I need to change to correct the problem? Other than bitrates, what should other settings should I be looking for? I can compare all the settings between TMPGEnc and Adobe MPEG Encoder.
Some of the settings I used in Adobe MPEG Encoder were:
Variable Bitrate
Video Bitrate: 6000
Video Encoder Quality: 39
I Frames: 15
P Frames: 3
Close GOP every: 1 GOPs
Example: BBIBBPBBPBBPBBP...
Variable bitrate: Max: 6000, Avg: 4200, Min: 2000
Motion Search: 9
Do half-pixel search
Noise sensitivity: 3
Color Primaries: ITU-R Rec. 624-4 System M
Transfer Characteristics: ITU-R Rec. 624-4 System M
Matrix Coefficients: ITU-R Rec. 624-4 System B, G
Multiplexing: none -
The most important ones: MPEG1/MPEG2, PAL/NTSC, Framerate, aspect ratio, resolution, audio (if any). But I think you have checked these already, therefore no idea...what should other settings should I be looking for
After Effects: Text Disappears..
By Coldkilla9 in forum Newbie / General discussionsReplies: 1Last Post: 29th Oct 2011, 14:09 -
Create scrolling text effect for Movie Credits using avisynth and png image
By wiseant in forum Newbie / General discussionsReplies: 6Last Post: 13th Sep 2010, 02:21 -
Video playback disappears, audio ok
By photoman99 in forum Software PlayingReplies: 7Last Post: 14th Aug 2009, 23:38 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 22:15 -
AUDIO disappears from my mpg's in playback! HELP!
By JMQL in forum AudioReplies: 6Last Post: 1st Jan 2008, 14:32
