My player runs divx, but not xvid. I've not interest in converting the file to DVD and taking up an entire disk, so I wanted to keep it around the size it is now, but in divx. I checked the convert guide briefly but can't see a simple prog to run it. Thanks![]()
Hello,
You could try virtualdub. It is quite robust and should handle just about anything you throw at it. Or try virtualdubmod which will handle more types.
FourCC changer.
The two codecs (divx and xvid) are pretty much comptaible with each other. All you need to do in most cases is change the header info (the FourCC) to get it to play. -
If I try this route, how do I change the header...? With one of the progs listed by Yoda?Originally Posted by bugster
Thx again
Bear in mind that changing the code may not be enough.
I can watch DIVX files on my PS2, and even most XVID files. However, the player is EXTREMELY bad at processing B-Frames and some of the other advanced features of the latest XVID codecs. Seems like everything I download uses those features, too.
So what I do is load up the file in VirtualDub... then INEVITABLY some monkey encoded it with broken VBR audio, so I extract the audio to a WAV. Then I set audio to WAV source (point it at that WAV) and 128KB/sec. MP3 CBR. Then I set video to fast recompress (you're doing AVI->AVI with almost identical codecs, no need to full processing) and to DIVX multipass... and let it rip. Takes a little while, but I'm in no huge hurry.
More often than not, though, I just run DVDSanta or some similar program and dump the stuff I download (mostly TV episodes that I missed, or stuff that was running while the DVR was recording something else) onto DVD. DVD's have gotten cheap.
How to convert WMP v9 (VC-1 Simple/Main) to divx/avi?
By ericdunn in forum Newbie / General discussionsReplies: 12Last Post: 28th Apr 2012, 18:09 -
Importing xvid and divx into vegas - a solution ?
By BJ_M in forum Video ConversionReplies: 55Last Post: 13th Apr 2010, 16:16 -
What is the best DVD to Xvid (or DIVX) solution?
By Chrushev in forum Newbie / General discussionsReplies: 8Last Post: 19th Jan 2010, 17:11 -
Simple Script to Prepare Your DivX/Xvid AVIs for Transcoding
By Soopafresh in forum Video ConversionReplies: 17Last Post: 13th Jul 2009, 21:30 -
Best Solution for DivX/XviD on a TV (Apple TV or Media Center Extender)
By fletch407 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Jan 2008, 02:08
