I have converted an avi to mpeg for burning to DVD, however TMPGEnc DVD Author rejects the file due to the resolution. Is it possible to change the resolution and if so what utility will do the job?
Hello,
Use bitrate viewer to double check your mpeg file. It should be mpeg2.
You can run your avi through tmpgenc to get a compatible mpeg2 dvd file.
If that doesn't work check the tools section under lists on the left of the screen for avi-dvd tools.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Is there anyway to reduce the resolution of the h264 video without changing
By theninger in forum Video ConversionReplies: 18Last Post: 3rd Jan 2010, 20:24 -
Conversion by changing video resolution results in a bottom rainbow strip
By usta in forum Video ConversionReplies: 3Last Post: 17th Jun 2009, 04:59 -
Changing Resolution Undesirably?
By hamid22689 in forum DVD RippingReplies: 7Last Post: 26th Sep 2008, 13:02 -
Converted video changing resolution.
By ZedFighter in forum Video ConversionReplies: 3Last Post: 22nd Aug 2008, 19:25 -
Changing Video Resolution
By Erf in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 23:16
