Hi, Could some1 pls tell me how 2 EXTRACT the audio out of an *.AVI file with DTS audio within pls??
I have installed AC3Filter with DTS audio codec built-in and it played and sounded ok with WMP. But I need to extract the audio out of the *.AVI file and it seem rather difficult than first seem.
I have tried numerous method and none seem to work:
SURCODE DTS
BeSure
Virtualdub
etc...
Pls advice what program i need and how it can be done pls, Thanks alot!!
Hi amdk62,
Check out the "Audio Editors" in the "Tools" section. Regularly recommend is Audacity (freeware, may do the job) and Goldwave (semi-professional trialware, more likely to do the job I'd guess). There are others...
Also, check the "How To... Convert" - there may be something under DTS to [audio format of your choice].
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
THX for your reply. The 2 prog u recommended doesn't deal with *.AVI file with DTS audio. So I am still needs help pls.
PS: I already know how 2 extract the audio out *AVI file with MP3/WAV/AC3 etc... -
An *avi is actually a container not a file type. Have you run GSpot against this file to see what the audio file really is? There is DTS with and without a flag, and other variations of DTS, so you need to know exactly what you're dealing with. If you can play it, then the codecs must be in your computer somewhere. TMPGEnc should be able to demux the audio and transcode it to something easier to handle, or IsoBuster could be used to extract and save the audio as is.
Hmm...interesting...If AC3Filter isn't decoding the DTS for me, then how come i get sound when i played the AVI (DTS) file???
Could some1 pls tell me where to get "Nero Digital Audio Decoder" from pls?? Is this file some sort of codec?? OR it is a separate software that deals with video/audio files??
Once i got the NDAD prog, what do i do then in order extract audio out the video file??
5.1 audio question - is a single .wav file true 5.1 DTS?
By jazzsander in forum AudioReplies: 5Last Post: 18th Apr 2012, 22:00 -
HELP for extract DTS or AC3 audio from MKV
By Riversound in forum AudioReplies: 5Last Post: 29th Jan 2010, 11:56 -
cannot extract wav from AVI
By ecc in forum AudioReplies: 3Last Post: 22nd Jul 2008, 19:21 -
Extract audio to WAV using VirtualDubMod
By jimmalenko in forum User guidesReplies: 15Last Post: 14th Nov 2007, 03:42 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 04:23
