Hi
Does anyone know where to download freeware to display AVI files as screensavers?
Hello,
Tried www.cnet.com???????
Yes. Go to www.google.com and in the middle of the page there will be a box, type "AVI screensaver" and then click that little button right under the box that says "search" on it.
I don't use screensavers, I know where the power button is and I'm not too lazy to press it. -
Hi all
Thanks for the replies. Did do a Google search before posting, but software either didn't work properly or did not indicate it was payware before I downloaded it. -
Cyberlink makes a program called Medi@show, that will let you use an MPEG1 saved as an .scr file; if you are in this forum, you will know how to convert .avi to .mpg. The version I have was on the Power DVD (version 3) disk that came with a DVD rom I bought several years ago.
It did not have a serial number for it, but I managed to find one that worked. BTW, it had several other programs on the disk that did not show up on the install splash screen.If it works, don't fix it. -
Found one called Media Screen Saver. It is freeware and does exactly what I need. Thanks again.
Brainiac
Looking to convert scr files (screensaver slideshows) to avi or mpg format
By wiltonp in forum Video ConversionReplies: 1Last Post: 23rd Jun 2008, 17:28 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 01:44 -
ScreenSaver to AVI -MPEG
By arturjose in forum Video ConversionReplies: 3Last Post: 25th Oct 2007, 09:03 -
Best freeware of dvd ripper to avi
By mai_hnf in forum DVD RippingReplies: 1Last Post: 31st Aug 2007, 22:45 -
Best Freeware for Avi to DVD
By videonewbie69 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jul 2007, 07:08
