Hello,
Im going to buy, for the first time, some blanks from blankmedia.ca.
There are many many choices there.
I have an LG-4040B burner on XP. I havent had any problems with any media I have tried so far (Memorex, TDK, Maxell, both + / - types).
From what is listed there, what are the better quality disks for the best price. What gives the best bang for the buck? I havent really looked at the site that much before so I dont know how their pricing works (ie. what was cheaper last week compared to this week, etc, etc).
Also, do they ever have "sales" or is it whatever is on the site, thats the price?
Thanks a bunch in advance.
LG
These. However, they're out of stock. I have yet to get a coaster with this media
Taiyo Yuden Silver 8X
Format: 0
Media Code Mfr: TYG02
Formatted Size: Not Formatted
Total Size: 4.38GB(4.71GB)
Book Type: DVD-R
Media Type: DVD-R
Media Code Id: 8.0x 11080KBps
Write Strategy Speed: 12.0x 16620 KBps
Current Drive Speed: 8.0x 11080KBps
Default Rotation: 0
Linear Density: 0
Layers: 1
Media Code:
00000000 00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0D 10 .l...@....R..... 00000010 66 78 80 00 03 54 59 47 30 32 00 00 04 00 00 00 fx...TYG02...... 00000020 00 00 00 00 05 AA A2 22 22 20 02 00 06 08 0E 11 ......."" ...... -
lol .. ok. Since they are out of stock, how about 2nd bang for 2nd buck?
I just dont want to buy something if its not worth it. Im sure you can empathize.
I dont want to by "X" disks for "Y" dollars and find out later that it was way too expensive.
LG -
Prodisc DVD-R might be the best "bang for your buck" media just because they are so godamn cheap while at the same time having a low failure rate (if you ask me). I would not trust them for really important stuff however. It depends on what you need.
BTC drives do it. To legit ones! On current firmware even!Originally Posted by Capmaster
And beware of TYG02 fakes!Want my help? Ask here! (not via PM!)
I'm in the Prodisc camp too, 1300 or so I might have seen 1 bad one, then again it might have been the not so reliable JVC standalone.
Prodisk seems to be a popular choice on the site as well. Tons of different models
What about Taito Yuden? There are a bunch of choices from them as well.
LG
Best 'bang for buck' GPU for PowerDirector 9 Ultra?
By rocknrolla in forum Newbie / General discussionsReplies: 4Last Post: 4th Jan 2011, 13:27 -
MKV player, best bang for my buck
By gold2040 in forum Media Center PC / MediaCentersReplies: 4Last Post: 29th Dec 2010, 13:24 -
Buck bang opinions
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 25th Dec 2008, 11:26 -
best bang for buck
By fergy05 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2007, 23:35 -
Best Bang for Buck in Upconverting DVD Player
By golfnut in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th Jun 2007, 18:40
