Hi,
Like alot of people, I tend to test my home creations on RW discs first before burning properly to save wasting discs.
I normally full erase these discs between use, but was wondering whether this was completely necessary.
Full erasing is obviously time consuming, especially when it comes to DVDs - is there any problems related to simply using quick erase instead?
Thanks.
After the initial format, I've always used the quick format and have never had any problems.
I always use quick erase on both CD-RW and DVD+RW. I've had zero problems.
AFAIK, a quick erase just resets the titling for the disk. When you burn a disk, it puts in the ones and zeros (Actually I think it doesn't burn ones, just zeros, but that's besides the point and maybe I have it the wrong way around) throughout the disk. When you do a full erase it just uniformly resets all of these, but since a standard burn on top of old data (as long as you did a quick erase) will do the same thing, it seems to me that a full erase is a waste of time.
In fact while I'm thinking about it I'd suspect that full erase would add slightly more wear to the disk, since where the data resides on the disk would be doubly burned: once with the full erase, and once with the new write. Disks are good for 100-1000 burns anyway, so it's not really a concern. -
Thanks for your replies folks... much appreciated.
It would appear that I'm going to save myself alot of time between edits!
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
External Hard Drives...How Full Is Too Full?
By bbanderic in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2010, 18:25 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
HELP - Can`t erase 10 dvd rw discs
By LOWTECH in forum DVD RippingReplies: 6Last Post: 13th Aug 2007, 15:28
