Not if they're sprayed evenly and lightly - maybe requiring more than one coat.
And, the latter is a case for personal preference and / or convenience.
Personally, when I start producing DVDs of personal holidays, friends weddings etc. - I shall definitely be wanting to take that extra bit of time to make the disc look good, having taken so much time to shoot it properly, edit it well, author it with good menus etc.
Results 61 to 90 of 114
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Sure.. I can see that in that case... I guess I meant more in a DAY TO DAY scenario
Cuban Cigars, Women and Movies.... What a wonderful combination!... I have a web site, and I've seen it... HAVE YOU!?
If you can read this, you do not need glasses -
bobaber,Originally Posted by bobaber
Are you saying you have sprayed the recording side and it still plays?
I am surprised. -
He just sprayed the recording side with Polycrylic and then immediately washed it off. Any water based product will do that.
Please, what's the spray intended for ?
What would happen if people don't use it ?
Zetti -
Nothing would happen necessarily. The purpose is to protect the disk from liquids that would ruin the surface and to give it a fine finish. Most people like the glossy surface but I much prefer the satin look and feel.
I'm new to printing on CD/DVD's and would like some clarification on this particular subject of spray coatings. Are you printing on "printable" CD/DVD's and then spraying to protect the image or are you printing on "regular" CD/DVD's and then spraying to seal the image so it stays on the regular media.
Thanks for any clarifications. -
Since the Minwax Polycrylic is water based, are you telling us that it doesn't make the printed side smear/run when you spray it? If not, then I'm gonna try some. I would think that any water based protectant would have an adverse effect on the ink.Originally Posted by bobaber
Has anyone printed on "regular" DVD's on an R200 and then tried to spray them? What is the harm (if any) in trying to print on regular media on an R200?Originally Posted by Bodyslide
I would imagine (though I have no experience) that the ink has nothing to bind to and so, at best, will sit very precariously on the surface and, at worst, will look like water on plastic and just "roll around".
Either way, I'd guess the ink is highly likely to be very unstable on the disc. Spraying may seal in a good print on the disc, assuming that's possible and that's what you get...
You gotta ask yourself why inkjet printable discs were invented... They're there for a reason I'd say...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
They are there to make a quick buck on the mentally unsound.Originally Posted by daamon
Bugger - That means they got me then!!!
Mind you, the difference in cost between printable and normal was only about AU$1 or 2 at a computer fayre I went to on Sunday.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Disregard all my posts on how great Minwax waterbased polycrylic is. I just tried Pat Nimrock and it is amazing. Its my choice from now on.
Bobaber -
Thanks for the information - I asked because I have plenty of "regular" and wanted to know the likelihood of printing on them (and have it stay!). Guess I will use them as needed and replace with printable.Originally Posted by daamon
Happy to hear this, but, I knew it!Originally Posted by bobaber
@John Fulcilives
I am watching you. Another post like this, and, Humm, I will do nothing
The insane rarely if ever realize that they are in fact INSANE so I feel an obligation to point it out :POriginally Posted by RickTheRed
Some people enjoy printing discs and others enjoy watching zombies gnaw on corpses. To each his own.Originally Posted by FulciLives
I say screw all zombies burning in hell thoughOriginally Posted by p_l
Anyone have problems with playback after spraying their disc? I use Pat Nimrocks matte finish. I am worried that after a while the disc will get messed up like with the sticky labels. The disc work fine right after I spray them and let them dry (ie. no spray on underside), but I am worried about long term issues. Anyone been spraying movies or PS2 games for a while and have some experiences?
Actually I express a similar concern as Yellowsugga. Wouldn't the spray melt & go gluggy & mess up the disk if it's playing in your player or burner? I know that disks get pretty hot there spinning around in my burner...
Besides, how does spraying a disk make it look even CLOSE to a professionally screen-printed disk? It can't!
I explored this when I put out a band's live DVD, it's just not worth it. I wouldn't even CONSIDER it for my DVD backups! Like the Zombie sez, it's kinda crazy!? Maybe "anal" is a better word for it?
But each to their own! :P
Cheers. -
but buying a printer instead of just using a sharpie is not....Originally Posted by NamPla
Just got an R200 and love the way it prints on inkjet printables. Looks great. I mostly print text information stuff and my logo in the disk directly from my home grown movie data base application.
As long as you don't get water on the ink all is fine. The ink doesn't smear with normal handing. However, The ink is water soluable even after it dries.
I have had one case of picking up a disk with some water on my hand from a cold glass and it smeared a letter on it.
I tried the Nimrocks spray and it works. Warning make sure the spray is completely dry before playing it.
I sprayed one, it felt dry, played it and it stuck to the hub in the player. ejected empty tray.. wtf... I was able to get it out with only a minor scratch on the disk from the tray scraping it.... how stupid can I be? don't answer that.
Anyway as others say, I only use the spray for special disks given to others.
The OldeMan -
I have used Pat Nimrocks for a while. It is a good spray, but if it gets o nthe bottom of the disc, then it ruins the disc. Anyone know of any products that will remove any spray that got on the underside of the disc without ruinning the disc itself?
I do not think there is something out there that can remove the product without removing the protective layer.
However, this other thread might help you to prevent reoccurence of this side effect of spraying.
https://www.videohelp.com/forum/viewtopic.php?t=239304
Happy spraying :P -
I used to be pretty anal about spraying discs. That was until yesterday. I had to do 20, my anal procedure would of taken a couple of days
Instead, I took all my hub primtable coasters and laid them out. Put the discs I wanted to spray right on top. Sprayed 20 DVDs all at once with 3 very thin coats. not one bad DVD out of the bunch
Remind you I used coaster of hub printabls -
how come people feel the need to put an extra something under the disk they are spraying??
Why is it not good enough to set the disk down on a paper towel or newspaper and spray them? will the spray crawl under it? -
The spray migrates, putting them on paper works fine, if you can place a small weight on the center hub to press them down to the paper. It's amazing how small a gap the spray can penetrate!
Just curious if anyone tried this with an Epson 320? My discs look great without the spray and I am truly considering trying it.
Also, I felt the need to reply to this post because I got alot of enjoyment out of reading it for the past 15 minutes, here's to hoping it comes alive again!!! LOL
Any tips on using the PM Spray would also be greatly appreciated.
TM
Found Two Meteorites
By budwzr in forum Off topicReplies: 11Last Post: 22nd Feb 2012, 10:34 -
caught a kid spray painting a neighbors car (vandalizing)
By zzyzzx in forum Off topicReplies: 12Last Post: 18th Oct 2008, 12:59 -
Spray on DVD media
By lin in forum MediaReplies: 15Last Post: 25th Dec 2007, 02:45 -
Found pulldownbatchFE
By Krelmaneck in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 15:17 -
Inkjet Fixative Spray
By werewolf_02 in forum MediaReplies: 22Last Post: 17th Jun 2007, 21:55
