Is there a way to capture and burn from my mini dv through firewire and burn directly to dvd writer ?
there is no need to edit my videos.
Thank you
Yes.
check out www.adstech.com devices that use the capwiz (propritory) software ver. 3.5 has a DTD option that captures and authors direct to media without using hard disk
The InstantDvd +Dv most likely is the one you want to check out as it accepts DV input. If you have analog source capability then you could get one of the others.
They will do what you specificaly asked for, but lack tv tuner scheduling
DTD does do auto chapter points, works great for me, but I use analog signal imputs.
Camcorder Direct to DVD
By Gregory J Lacey in forum Newbie / General discussionsReplies: 0Last Post: 2nd May 2010, 04:23 -
can I burn avi's direct to jump drive or computer desktop Toast9
By BattyRoy in forum MacReplies: 4Last Post: 10th Aug 2009, 00:06 -
DV Direct to DVD (DV Capture)
By coisty1856 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 13th Sep 2007, 15:15 -
Direct TV DVR to DVD
By cspring72 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2007, 18:00 -
Capture / Burn direct to drive
By Bob08 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2007, 16:28
