This is so annoying, what the hell is this cygwin thing anyway and why does it always get messed up.
When i first bought this program it was working fine, some months down the track it stopped working and i seen a post that said download cygwin off the internet and install it which i did.
This fixed the problem and it worked fine, once... now the program wont even load it just says cygwin1.dll is being used by another program.
mscorlib error....
i cant delete the file because its in use... anyone have any ideas?
something that will make it work normal again without having to edit it all the time....
and is there an update that will fix this problem ?
thank you
Can you show me a screenshot of the error?
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 18:58 -
RUNDLL memsprm.dll
By BLSAMPLES in forum ComputerReplies: 5Last Post: 29th Sep 2010, 08:06 -
MPEG2.dll
By Black-Logik in forum Video ConversionReplies: 6Last Post: 21st Mar 2009, 03:40 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 14:34 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 18:28
