I'm capturing with a Canopus ADVC-100 and am having a problem with Premiere. After about 18 minutes into a capture, the capture stops and prompts me to begin a new capture file. This happened a few times in a row. I'm manually starting my VCR or camcorder to start the capture and then pressing the Record button within Premiere. I have plenty of HD space and no known PC issues. Any suggestions? Thanks.
That sounds like your hitting the 4 gig limit on a FAT32 fomatted HD.
Go to my computer, right click on the HD your capturing too, select properties and on the general tab see what file system your using. If it's FAT then that's the file size limit. You'll need to have a NTFS formatted drive to capture files over 4 gigs.
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 15:16 -
Adobe Premiere Pro Not Recognizing Capture Card
By ercdill in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2008, 15:59 -
Adobe Premiere pro problem, clips in the program is black
By Ces123 in forum EditingReplies: 5Last Post: 19th Aug 2008, 19:56 -
Adobe Premiere Pro CS2 Keyframe Problem
By fizzle in forum EditingReplies: 0Last Post: 25th May 2008, 18:39 -
Adobe Premiere Pro 2 Problem
By mymuckaccount in forum Video ConversionReplies: 2Last Post: 20th May 2008, 16:17
