  1. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    im looking for a program that can scan my backup vcd for any error (skipping, stopping of the movies). will scan for error in virtualdub do this?
    i sometimes backup the original vcd of my friends and some clients for their own use and sometimes i don't have anymore time to view the whole movie in the backup vcd in my standalone player before i gave the ouput to my friends or clients...
    hacking the Net using typewriter :D
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Virtualdub (and its variants) will open MPEG-1 without a hassle. I've never tried using the error scan in vdub on MPEGs, but in theory it should work the same as it does on AVIs. There are also a number of MPEG tests you can run in VCDGear.
    If in doubt, Google it.
  3. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    thanks a lot ill check them out...
    if other have anymore suggestions please don't hesitate to reply...
  4. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    There are also a number of MPEG tests you can run in VCDGear <<< where can i find this mpeg test in vcdgear?
  5. Try this guys way of fixing VCD's with errors........worked for me.
    https://www.videohelp.com/forum/userguides/153907.php
    Good luck.
