Results 1 to 9 of 9
    Nov 2004
    Brazil
    What would be a good computer for ripping/burning DVD? Should I waste more with RAM or what?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Knowing what you've got might help.
    Read the DVD Ripping Speed Tips sticky in the DVD to DVDR forum for advice on gaining good ripping speeds. It does not really matter what machine you have for burning these days. Encoding/Transcoding is heavily CPU-based, but lots of RAM does help.
    If in doubt, Google it.
  3. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    "What would be a good computer for ripping/burning DVD?"
    Well, that is a very general question with many answers. Having a computer with a dvd burner is a start. And as jimmalenko stated "Encoding/Transcoding is heavily CPU-based".
    "Should I waste more with RAM or what?"
    Maybe you can start by telling us how much ram do you currently have. And while you are at it fill out the rest of your computer details. It will allow us to better help you in the future.
    Nobody likes a bunch of yackity-yack.
    Nov 2004
    Brazil
    I already have 1GB RAM
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Why don't you fill in your Computer Details in your profile ?
    We can't see your computer from here
    Nov 2004
    Brazil
    Done
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I think the only thing you need is a LiteOn DVD-ROM and you'll have one heck of a machine.
  8. Member SLICK RICK's Avatar
    Mar 2003
    And while you are in your computer, you may want to throw in another hard drive.
    Nov 2004
    Brazil
    Ok, thanks Jimmalenko and Slick Rick for your time and help
