Good Morning
Sorry i was unable to find where to out how to put this on the dvd hack page.
I bought a portable DVD player in the United States
Audiovox D1712
due to wrong zone it will not play DVD's in Australia
This was a present for my daughters 18th birthday
if someone could help me i would really be eternally grateful
Thank you
Sharon Nimmo
Australia
According to the pdf for that model I downloaded from their web site, the region code is fixed for the country for which it is sold. In other words, you should have read up first, before spending your money. Some machines will allow a minimum number of changes to the region code(usually 5) but this one will not. If your daughter has a computer, have her read up at this forum so she can rip the movies she has and make them region free. Sorry, mate, DRM sux big time, and you've been had.
Thanks for your quick reply yes i have been had i told the guy that i was from Australia and asked him if there would be any problem with playing dvd's at home before i bought it.
Thanks anyway -
Good Evening,
Similar situation to Sharon from Australia - I'm from Argentina and recently bought a portable DVD player Audiovox D1812PK in the United States,
which is zone 1, so it will not play my DVD's from zone 4 (Argentina).
I was wondering if someone can help me find out if this dvd player could be hacked to make it multi-region, or if I have to do the same as Sharon was suggested.
(I know, I know... do more research before spending your money - but it was a language problem / it said it was "multi-system" and I understood it was "multi-region").
Thanks in advance
Alberto Y.
Argentina -
Re: the Audiovox D-1812PK, Found this tip at B&H's website, under the product specs: (http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=332778&is=REG)
"To change region codes:
Power on, Press open on the DVD player
On the remote control press the SETUP button,
Press the right key 3 tiems
The preference page will show up, press 9653,
Use the up and down key to select the Region,
Select 0 for all regions"
I'll try it as soon as I get the DVD delivered and will post the results. If in the meantime somebody could confirm that it works will be appreciated.
Thanks again and regards,
Alberto Y.
Argentina -
Hello this is Sharon do you know if the above will also work on the Audiovox D1712 or does anyone else know of a code that will work on this model
Thank you
Sharon
VB code to read DVD Control Data Zone
By casejustin80 in forum ProgrammingReplies: 0Last Post: 28th Mar 2009, 12:34 -
Can an ATSC tuner in an HDTV read a DVD zone 2?
By julax in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2009, 12:12 -
Question about zone burning rings on DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2008, 17:24 -
Free zone Citizen C201 DVD
By Pap in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Dec 2008, 01:00 -
Looking for a region free /zone free DVD Recorder. Questions about the zone
By perdue27 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 10th Mar 2008, 15:09
