I have a .avi file in DivX form and I need to get it to play in my DreamCast (using Gyplay or a similar program). I tried it once and Gyplay came up with "Error2". Is there a place I can read Step-By-Step instructions? thanks!
I DID try and use AVISplit then some .avi to MPG1 converter which took a full day (i know they take awhile though)... Any Help at all would be great... Thanks!!
did you try the dreamcast movie maker listed under TOOLS? i have never tried it so i can't tell you if it works or not.......
Dreamcast video
By Avatar in forum Newbie / General discussionsReplies: 24Last Post: 10th Sep 2009, 19:38 -
Unlikely console revival - Dreamcast ??
By Noahtuck in forum Off topicReplies: 9Last Post: 8th May 2009, 19:44 -
Is the Playstation 3 destined to go the way of the Sega Dreamcast?
By yoda313 in forum PollsReplies: 32Last Post: 21st Jan 2009, 17:18 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Encoding Dreamcast onto iMac for fullscreen viewing
By karas in forum MacReplies: 5Last Post: 13th Nov 2007, 09:00
