I have a Video_TS folder in my hard drive that I want to burn to DVD-R5 with Nero burning rom. When I do so Nero reports the following message:
"DVD-Video files reallocation failed", "Video title set containing 'VTS_02_0.IFO' is not required".
Should I burn the files anyways? Will the DVD be playable?
Thanks.
Yes, they'll be fine.
I've had this happen 3 seperate times. I just ignored the error and continued to burn.
everything turned out fine.
Use a DVD-rw if you want to make sure it will work on ur stand-alone.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD burning problem
By eunhye in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2008, 20:04 -
DVD Burning problem
By eXit- in forum Authoring (DVD)Replies: 7Last Post: 1st Aug 2007, 10:42 -
DVD burning problem
By Neil_2004 in forum DVD RippingReplies: 12Last Post: 30th Jun 2007, 18:14 -
DVD burning problem
By ea7770 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2007, 15:17
