  1. evening ppl
    I got a avi file recenly, however after i convert to DVD, the audio is rather soft.
    anyway for me to rectify this ?
    some guide/steps would be a great help..Thks alot
    *newbie on learning track*
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    It's all here. You just have to sort through it and find what's relevant to your project:
  3. Oh...well..rather new to all this..thus dono which to chose also...
    sorrie for such kinda of post
  4. anyone can help me with this..? wat mus i do
    OR just point a guide for my reference pls..thks
  5. Serene Savage Shadowmistress's Avatar
    Mar 2004
    Controlled Chaos
    I believe you need to re-encode the audio part and use the "normalize" feature on the converting tool you used. Set nomalize to however loud you want it. ie: if you want it twice as loud set it to 200%.
