Hi ppls
me have a problem here when joining 2 movie avi file together...it show audio streams have Different sampling rates.![]()
How can i solve this.??? can the file be merge due to the error ???
any guide to follow ???
pls advise... :![]()
Closed Thread
You can try something like this with AviSynth:
AviSource("clip1.avi").AssumeSampleRate(xxxxx)+Avi Source("clip2.avi").AssumeSampleRate(xxxxx)
etc, etc.
Or you can load them one at a time and resave them with VirtualDub then join them once they all have the same sample rate."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
"....AviSource("clip1.avi").AssumeSampleRate(xxxxx )+AviSource("clip2.avi").AssumeSampleRate(xxxxx)
etc, etc.
Or you can load them one at a time and resave them with VirtualDub then join them once they all have the same sample rate...."
thks..but for the first wat shld be the sampleRate be ? i am converting the file to DVD
secondly, open at virtualDub then save ? don need to do any setting change ? don really understand wat u mean..
If you're using AviSynth just enter a 48000 value for DVD compliant sample rate. Then open your script in VirtualDub and click in file menu -- >Streams>Streams List>Save WAV, like usual. Your new WAV file will have whatever sample rate you entered in your script. Then business as usual...
Ooops...ignore that. I was thinking of something different. Just use full processing mode, select whichever codec you want to compress with and click save and resave as a new AVI. The sample rate will be right.Originally Posted by sacajaweeda"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Please do not cross post (https://www.videohelp.com/forum/viewtopic.php?t=243782). One topic is enough
Topic locked
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 07:46 -
Of PAL DVDs, .avi files, and frame rates
By AlphaCat in forum Authoring (DVD)Replies: 4Last Post: 30th Jan 2012, 09:23 -
The audio streams have different sampling rates, blah blah
By Kobong in forum EditingReplies: 5Last Post: 8th Jul 2008, 07:07 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 08:03
