Results 1 to 9 of 9
  1. Hi ppls
    me have a problem here when joining 2 movie avi file together...it show audio streams have Different sampling rates.
    How can i solve this.??? can the file be merge due to the error ???
    any guide to follow ???
    pls advise... :
    Apr 2002
    Oskeeweewee Ontario
    Ummmm, why don't you tell us what software you're using, and what's your final format..
  3. hmm..virtualDub ...converting avi to dvd..But me wanted to join the 2 avi file to one first..
    heard it might be easier to convert to mpeg then merge them togther ? any comments on tat ?
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Less troubles that way. You actually can "merge" them at the authoring stage. Leave them as separate mpegs and author so that they play one after the other.
  5. Originally Posted by ZippyP.
    if i leave them as seperate mpeg. does tat mean when playing..after the first mpeg it will stop n go to selection page ? or will it auto play the next track ?
  6. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You can select that when you author. If you add them to the same track they will play one after the other.
    Apr 2002
    Oskeeweewee Ontario
    No doubt, ZippyP. is correct..
    But as to your original post, Vdub requires exact same framerates, codecs, and samplerates to join two .AVI's together...
    Your other option would be to get one of the .AVI's, and Recompress and Convert samplerate, and bring it back in..
    Once you've got this reconverted .AVI, you shouldn't have a problem joining the second .AVI..
    Confused??
  8. Member SaSi's Avatar
    Jan 2003
    Hellas
    Yes, but authoring this way would it make it impossible to fast-rewind from title 2 to title 1?
    The more I learn, the more I come to realize how little it is I know.
  9. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Good point. You could try converting the audio in each avi to wav first, then joining after. To convert the audio load into Virtualdub, set the audio to full processing, set the video to direct stream copy then save avi.
