(connection lost on previous post ... sorry if this appears to be a repost)
Hi all,
I've been trying to rip music videos (or specific chapters) off a DVD using DVD Decrypter and SmartRipper. While new VOBs are generated, how can I convert this to AVI/MPG *WITH SOUND*?
The objective is to create my own VCD/DVD of my favourite music videos. But when I used TMPGENC XPRESS to convert VOB to MPG, I realised there is *NO SOUND* (under the cut-edit screen, it says NO AUDIO AVAILABLE). Renaming .vob to .mpg only gives you the illusion this is OK eg. when played with Windows Media Player, therefore this technique is not what I'm after.
Must I go through the process of demux/mux the video/audio files?
If so is there a guide out there which summarises these steps?
Some points to note ... I've already tried several combinations with SmartRipper's StreamProcessing options. I also have AC3 codecs. The VOB does contain audio, I've even successfully demux'ed it into separate audio files.
Any help would be most appreciated!
Excalibur
Drop the ripped .VOB files straight into TMPGEnc DVD Author, and edit it to your own preferances.
If you want to convert to VCD, create a project file (.d2v) and a WAV using DVD2AVI, then encode with TMPGEnc:
https://www.videohelp.com/guides.php?guideid=78&howtoselect=4;11#78
Cobra
Having trouble using DVDx to rip to .mpg or .avi
By waldothewonderboy in forum DVD RippingReplies: 19Last Post: 30th Aug 2010, 03:48 -
How do I Rip sound effects and music separately?
By tapir in forum DVD RippingReplies: 9Last Post: 19th May 2010, 01:04 -
Is there an easy way to determine the frame size of videos?(avi, mpg, etc)
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 15:45 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 18:15 -
mpg with a good MP3 sound in music videos
By copiche in forum AudioReplies: 5Last Post: 24th Aug 2007, 12:22
