hi i am trying to convert an mpeg file so dvd meastro will suport it im using tmpg encoder 3.0 express but can anyone tell me the settings i need to set the mpeg to so that dvd meastro will support (i want it in PAL),
because when i convert it with tmpgenc it just says ''media not supported error (0xc10b0002)'' can anyone help ? will b much appreciated
Results 1 to 9 of 9
~steve~
Maestro takes elementary streams. .MPV, .M2v and .mp2, .wav .ac3 so on and so on.
Maestro will not import a multiplexed file. -
i dont really understand what that means but i have converted my file to mpeg 2 recently but it still says it wont support it is there something im doing wrong?
~steve~ -
A multiplexed file is a file that includes both audio and video. A stream, is a file of just video or just audio.
MAESTRO DOES NOT SUPPORT MULTIPLEXED FILES
It's located in the manual and the help file for Maestro, and is in several guides here on this site. -
if u dont mind could u answer another quik question i have converted the audio and im just about to convert the video was just checking if these settings are ok or if they need adjusting
output stream format - MPEG-2 program (VBR)
stream format - MPEG-2 video
size - 720 by 480 pixels
aspect ratio - 4 : 3
frame rate - 29.97 fps
rate control mode - CBR (constant bitrate)
VBV buffer size - 224kb
video stream - PAL
DC component Precision - 8 bit
video mode - progresive
motion search precision - standard
bitrate 4000- kbits/sec~steve~ -
Read some of the guides, and make a trip to the glossary and what is sections on this site. You had every setting for NTSC set, but you stated you wanted PAL.Originally Posted by steve9173
i just had settings on what it started on but thanks alot for the help ive asked on other forums but no1 had replied so thanks alot for the help!
~steve~ -
Not a problem.
I'm refering you to the guides, because there is a bit of info for noobs and old pros too. Plus the people that write them spend an awfull lot of time and effort to put them together.
If you have any other questions, just post, and someone will be along to help.
I need a DVD movie supplier, PLZ!
By caesarhawy in forum Off topicReplies: 0Last Post: 17th Mar 2009, 02:54 -
Anime Backup Question Plz Help :)
By Azures in forum DVD RippingReplies: 2Last Post: 2nd Jun 2008, 16:37 -
encoding and dvd authering help plz
By lucid_dreams in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2008, 17:05 -
DVD Lab Pro 2.5 help plz
By lucid_dreams in forum Authoring (DVD)Replies: 15Last Post: 3rd Mar 2008, 16:13 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
