I ran across this on the BB site. Buy one get one free. Thats a very good deal on this media. Im thinking Ricoh R02 maybe for the plus. I wonder about the minus.
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat45800050024&type=category
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat45800050025&type=category
Results 1 to 30 of 34
I know the 15 pack spindles that were on sale a few weeks back at office depot were CMC for both DVD+R & DVD-R.Originally Posted by dmagic1
The 25 pack spindles I know from COMPUSA are DVD+R PRODISC & DVD-R FUJIFILM03.
If anyone purchases these 50 packs let us know what the media codes are.
They look the same as the ones I bought a couple of weeks ago.
I bought 100 +r 8x
They do not burn at high speed in either of my burners.
Nec Nd 1300A +- 4x
I/O Magic +- 8x
burns in either took 45 minustes (about 3g data)
Used nero6 and Record Now with same results
says burning at 8x but I know that is not the case given time
sorry not a techie so don't know media codes etc.
also had insert warning of data integerity if used in 4x burners not upgraded via firmware to 8x -
snafu099,
What was the media code?
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
If it took 45 minutes for 3 GB's of data, you have other issues other than the media. I would upgrade to the latest firmware for your drive and be sure your IDE channels are set to UDMA. That is burning at 1x and something else is wrong if that's the case.Originally Posted by snafu099
Tom -
Originally Posted by hecklernumber1
Check this out for an explanation.
https://www.videohelp.com/dvdmediaform.php?dvdinfo=1#dvdinfo -
I'm curious on the +R media codes too.
I was just at the store and noticed two different packs of the +R media...
1) Taller pack with deep (1/8") indented ring on the top of pack, foam ring and spokes on bottom of cake pack.
2) slightly shorter pack, no foam ring and no deep indentated ring on top, smooth bottom of the cake box.
I'd be curious on what anyone knows about either pack.
EDIT: Fixed description -
I just got 2x50 and they are Ritek R03 but they just look like regular cake boxes to me .I couldn't see 2 seperate types so maybe my store just has one type of +R.
Tom -
DVD-R is probably CMC MAG AE1
DVD+R is probably CMC MAG EO1
https://www.videohelp.com/dvdmedia.php?dvdmediasearch=memorex&dvdmediadvdridsearch=&typ...+or+List+Media -
Best Buy also has TDK 8x + and - R 25 pack for 9.99 no rebate
media code was CMC MAG E01.any comments on these.I couldnt find them in the media listing.Input would be helpful I'll burn a couple later and give results,using myNEC2510 and NEC2500A -
Tom, can you check the bottom of the pack? The difference on the tops is a small lip on the outter edge of the smooth bottomed ones. The spoked one has a deeper ring about an inch and a half wide below that you can see the foam ring.Originally Posted by jtommyj
What did you get? I'll try to post pictures later tonight. -
You'll need to post the pictures so i can let you know.
I can't really tell from your description.
Tom -
These are usually Ritek R03s or Ricoh R02s and many times in the past they have been on sale from $30-$40.
http://www.newegg.com/app/viewProductDesc.asp?description=17-132-344&depa=0Still a few bugs in the system... -
Those are the RicohjpnR01 4x that burn at 8x that i received. They are great discs. I've bought about 400 of those and 3 times i got a 10 dollar rebate.
The Memorex 8x i got from Best Buy are Ritek R03 which i've never received
from Newegg in my 4 spindles.
Tom -
Type that is lower profile, no styrofoam ring, smooth bottom
Type with a taller profile, styrofoam ring, spoked bottom
Here you go these are the two types I've found.
The bottom is kinda tough to tell from the photo, look for "spokes".
EDIT: Not sure what happened to the the thumbs, click through should work...
EDIT2: Got thumbs back -
Just made it back from the store I bought discs from yesterday.
There were LOTS of discs there yesterday, but today.... NONE.
Someone catch wind of this and gobble up the entire stock? I have no idea, but it looks like Milpitas, CA is OS. -
OK, jeff d, i looked and mine don't have a spoked bottom, they are smooth with an inner ring. Sorry it took a while but when i checked back the pics weren't working. Mine are like the top photo.
Did you try to order them over the net and pick up at the store option ? Maybe they set some aside for Internet orders.
Tom
Thanks tom. good info, I'll be sure to check those out first. I just picked up in the store, nothing special about online order. There were like 50 packs yesterday and none today.
Can anyone else confirm media codes on the discs they got? -
I've been hearing allot about the media codes but I got a question: Is the deal worth it to buy (2 - 50 DVD +/- R's for $39.99)
No. Not unless you love that particular code.
http://www.rima.com/Merchant2/merchant.mv?Screen=SFNT&Store_Code=RStill a few bugs in the system... -
Has anyone with a Optorite DD0203, bought these memorex. I am having trouble I have a 4X dvd+-r/rw capable burder, but with these 8X capable disc and only able to get 2.4X max speed burn. Is this a firmware issue, if som how do i update the firmware. Please help
if anyone interested:
BB still has it deal this week in form of 50 pack for 19.99
i picked up -R's yesterday ( in PA) and they were Ritek R05
burnt and verified ok (8x in pioneer108) -
Looks like these prices continue.
Memorex
Circuit City has 50 for $19
Office Max has 50 pack buy 1 get 1 for $39.
Verbatim
Best Buy 50 for $19 -
i recently picked up 2 fifty packs of these and they were prodisc. they were listed as 8x but i was able to burn them at 12x in my optorite dd1601 in about 6.5 minutes. i have had no problems with playback yet.
I picked up a 50 pack at CompUsa . Not a good read in my Plextor 708. Only one burn so far. A 4 gig clone of a drive. No problems restoring the information. I will not trust these discs for important info/burns.
Memorex 8x -R
Manufacturer ID: Prodisc F01
Supported Speeds: 4.0X - 2.0W - 1.0X
The dye appears to have spun out beyond the edge of the Media ring. There are dye smudges inside the the inner ring also.
The Memorex logo inside the inner ring looks impressive but the disk itself looks quite tacky.
Memorex DVD+R DL on sale
By GideonK in forum MediaReplies: 6Last Post: 9th Nov 2011, 20:38 -
Memorex DVD-R
By ozab in forum MediaReplies: 9Last Post: 15th Oct 2009, 19:37 -
Wow, how hard can it be to just copy a DVD ?
By liffy99 in forum Newbie / General discussionsReplies: 16Last Post: 6th Feb 2009, 14:32 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Setting up short repetitive WOW trailers on dvd (in HD)
By malisamson in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2008, 05:36
