I'm looking for a way to increase my upload bandwidth. I have cable internet access now with 65 kBs right now. I was thinking about geting DSL, but I want to know if it works. I see advertized speeds very alot, and it dosn't look to me that they distinguish between kbs and kBs. Bytes and Bits. Anybody have info on this, or links to info?
Thanks Mike
Results 1 to 11 of 11
WHare in the world are you as it could make a lot of diffrence....
Here in the UK we get 256kB/sec uploads.Not bothered by small problems...
Spend a night alone with a mosquito -
Bazooka
What company do you have? Would you give me a link or someother info, so I could check them out?
Thanks Mike -
I have SBC DSL and I get anywhere from 300-500kbps up. The plan isn't listed on their site but it's $45/mo plan. I believe it's rated 6Mbps down / 1.5Mbps up.
Nothing can stop me now, 'cause I don't care anymore. -
ViRaL1
Your #'s bring up a point. 1.5Mbps rated up speed, but actual 300-500 kbps. That looks to be a big differance, to me. Is that normal? should I be looking for a drop off of that much from the advertized speed? Am I reading that right, thats about 1/3 of the advertized rate?
Bazooka
Thanks I saved the link, it has good info. I think I am going to have to call some of these places.
Thanks Mike -
Ditto... I'm on Verizon too..... very decent speeds... and it doesn't suffer from the Comcast slowdows I've heard about that occur aftre 6:00pm.Originally Posted by bazooka
Tim -
Well, I am jealous all around as I have Verizon ADSL as well. Due to older wiring in my apartment building I am limited to their 768/128 plan which only works out to 84kB/14kB after overhead. Still better than dial up though.
No, I'm from Iowa. I only work in outer space.
question about bandwidth usage
By mazinz in forum ComputerReplies: 8Last Post: 11th Nov 2010, 20:32 -
Low bandwidth formats for TV mashup
By DrSpirograph in forum Video ConversionReplies: 3Last Post: 5th Sep 2009, 11:00 -
How much bandwidth is used in a typical 1 minute video?
By chrisj in forum Newbie / General discussionsReplies: 10Last Post: 13th Mar 2009, 14:37 -
1080p over LAN bandwidth?
By W_Eagle in forum DVB / IPTVReplies: 6Last Post: 28th Jan 2008, 08:11 -
Does quoting someone else's post use bandwidth?
By moviebuff2 in forum ComputerReplies: 5Last Post: 15th Jan 2008, 20:16
