Full of questions tonight sorry.
I applied a filter and then i select "preview filtered" then i have 2 windows on my screen of the video. Which one is the filtered one? the one on the right or left?
The left is input, the right one is output. Remember Options=>Swap Input/Output panes comes in handy when working with extra large resolutions.
Also right clicking on either pane brings viewing size options.Hello. -
Ok cool ty.
Another question....
I applied the filter I want to use and now how do i make the program output the video with the new filter applied?
I cant find good directions for this so any help appreicated! -
There are two ways, first is to use the "save as AVI" function in v-dub to save your new AVI. The only problem with this is that you will end up with a file that's really big all the way up to enormous.
The second way is to frameserve the file with filters to a program such as TMPGEnc which will encode it directly to DVD compatible MPGs. Frameserving is a simple process which is outlined in the guides here."Rarely is the question asked: Is our children learning?"
George W Bush - Moron -
ok i see that the TMPGEnc converts to mpeg so i think i should be more specific as to what im using. I am using the virtualdub mpeg2 therefore my file is all ready in mpeg format. I tired saving as an avi and all i get is a tiny file that is nothing.
So knowing what im using, is the best way to still use the frameservering? -
And the third way is to select a codec using Video=>Compression... Select the codec, its parameters, then OK. Then use the File=>Save As option.
Hello. -
Poolplayr- I understand you are working with MPG, but it doesn't matter. v-dub mpeg2 won't save as an mpg. You are either going to have to save as an avi and re-encode or frameserve and re-encode.
I'm not sure why you were not able to "save as AVI" because I have done this easily with v-dub mpeg2 on many occasions.
Tommyknocker- This will not work in v-dub mpeg2. You must be thinking of v-dub mod in which case this is the same operation as I descibed above, but for a different program."Rarely is the question asked: Is our children learning?"
VirtualDub Output question...
By nharikrishna in forum EditingReplies: 8Last Post: 22nd Nov 2010, 23:27 -
VirtualDub question
By s3r19lk1ll3r in forum EditingReplies: 5Last Post: 15th Oct 2010, 17:43 -
VirtualDub question
By Rogert in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2009, 12:22 -
virtualdub question
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 13:34 -
virtualdub question
By cowboysroy31 in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 12:50
