Thread: Cleaning up an old movie.......
  1. #1
    I got an old movie the kind with no sound and the flickering through out it and I read about the MSU old film recovery which looks awesome but you cant download the filter however is there another plugin like this one out there i could use instead?
    Mod Neophyte redwudz's Avatar
    USA
    Posts
    24,327
    A good place to start would be Virtualdub. There are a lot of filters to play with and more can be found at:http://neuron2.net/
    If you capture the film as an AVI then take a small representative segment of a minute or two and experiment with some filtering, you should be able to make improvements. Don't expect miracles, the pros have very expensive equipment to play with to get to the finished product.
    Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Posts
    2,531
    Yeah I would think you want to be capturing to AVI and use a TBC. Use the best player you can to get the best output quality and flicker reduction. Try it in different ones if you can. Then once you have it capped (uncompressed AVI if you have the space) start playing with some sample clips of your source using VirtualDubMod & AviSynth using different filters, etc. Cleaning up old stuff is a pain in the ass but sometimes you can get pretty decent results. I like using the Dust & MSharp filters for AviSynth for a lot of the old VHS stuff I had that I restored & backed up to DVD. The Tweak settings for adjusting brightness, contrast & saturation levels are useful also. I like the AviSynth - VDubMod combo because you can preview your filters as you change them in your script editor by just hitting the F5 key. Slow going restoring this stuff though, but it's worth it.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
    Member NamPla's Avatar
    Jun 2004
    Whoop Whoop
    Posts
    496
    I'm no expert on this, but doesn't it sound like he needs some kind of "inverse telecine" on this? Progressive frames?
    If it's just video noise, I know as a fact that Avisynth's Convolution3D plus TMPGEnc's Sharpener does WONDERS.
    Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    Posts
    3,821
    sounds like he's talking about an old silent film... which means it's probably going to be quite a job fixing any flicker...
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Thanks all for the input. Yes it is an old silent film. The reading for these tools are pretty intence and my bookmarks have quadrupled. I diffently have alot to learn!
    Jun 2004
    Whoop Whoop
    Posts
    496
    I think Housepig is right. If they could remove that "flicker" from old silent films, they would've done it before it hit TV/video/DVD whatever. It's just part of the old nostalgic "package". I think they shot at less than 18fps back then in the '10s & '20s... The human eye needs more than that to give the illusion of fluid "motion".
  1. head cleaning
    By kb 801f in forum Newbie / General discussions
    Last Post: 28th Nov 2010, 12:09
  2. Cleaning Up Audio
    By Yeah in forum Audio
    Last Post: 9th Apr 2010, 23:41
  3. Cleaning the lens?
    By Digiface in forum DVD & Blu-ray Players
    Last Post: 14th Sep 2008, 10:27
  4. Cleaning up Picture?
    By LCE in forum Video Conversion
    Last Post: 15th Nov 2007, 10:47
  5. Guitar Cleaning
    By Squid_uk in forum Off topic
    Last Post: 24th Jun 2007, 01:17
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
