hi I just put my combo and pioneer 108 on a 80 wire 40 pin on secondary, and burned on alcohol 120% at 8x, but it only burned at 4x? Never happened to me before, been using same media. Tried burning a audio cd with 21 songs to 32x and it took like 5 minutes. That isnt right? Could there be a problem with 80 wire 40 pin ? Or the combo doesnt like being connected on the same ide? Or what if the combo and pioneer 108 are on primary , and I put my hard drive to secondary? I thought primary was always for hard drives and secondary was always for cd-roms and cd burners?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
"What It Do"
Huh ????? -
I doubt if primary-secondary is your problem. Newer MB and drives don't care that much. I usually put the burner as secondary master and the DVD ROM as secondary slave. Primary slave is good for IDE backup or video storage.
80 wire can only help. Have you checked your PIO-DMA status? XP may have reset it. Nero Info tool is handy for checking, or you can go into Task Manager. Check IDE channels, Advanced.
If that fails, delete your IDE channel for that drive and Windows will replace and reset it. -
Originally Posted by redwudz"What It Do"
Huh ????? -
If your combo is UDMA 2 and the 108 is UDMA 4, that's about right. You may have problems elsewhere. You can go ahead and reset the IDE channel just as you have described, though. If no luck there, try another IDE cable. If you are using flat cables, they're cheap enough just in case it is a flakey cable.
Sony RDR-VXD655 Combo VCR/DVD Recorder Problem
By massspec in forum DVD & Blu-ray RecordersReplies: 0Last Post: 1st Jan 2012, 20:31 -
LG DVRK898 DVD Recorder/VCR combo problem
By imlost in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Jul 2010, 13:03 -
Problems with Alba 108 DVD player
By Normie in forum DVD RippingReplies: 1Last Post: 13th May 2010, 11:44 -
Sharp’s 108” LCD TV on sale for $185,000
By fairytale00 in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2008, 20:02 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 04:36
