the box clearly states that it plays MP3's but i tried an MP3 disc and it wont play. The same MP3 disc plays fine in all my other DVD Players, but not this one.
Has anyone else with this DVD Player had any problems playing MP3 discs and if you fixed it, how did you fix it?
Hello,
The dvd player list on this site shows it can play both cdr and cdrw so that shouldn't be the problem.
What bitrate are your mp3's??? Some players have limits on them.. If they're too high they might not play correctly.
Also, always try different brand discs if it doesn't work
Good luck
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
VCR/DVD Combo Unit
By xtreemman in forum Off topicReplies: 2Last Post: 6th Dec 2007, 15:12 -
Help deciding for VCR/DVD combo
By UltW in forum Newbie / General discussionsReplies: 7Last Post: 2nd Oct 2007, 22:45 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02 -
Samsung converting VCR (not DVD) playback problems?
By ecc in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th May 2007, 12:38
