I have been using NERO 5.5 to make VCD, but, I have a question about some options I see under the Video CD TAB when using New Compilation and set on Video-CD.
What I am referring to is a window between the "Use Cd-i application" and the "Store source pictures in" check boxes, and have command in it like:
CONTROLS=ALL
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
What are all these for? Can I change them? What will happen if I change them? What would happen if I remove them all?
I really hope that these can be used to fix a problem I have using menus with PowerDVD.
It seems that after displaying the menu page for 5 seconds PowerDVD automatically starts playing the video (or the last video if more then one is on a CD). No problem in WinDVD
I always thought it was a problem with NERO, however, I have recently found that menus made with Ulead's Movie Factory will only display for 30 seconds (which happens to be the length of the background music I use over the menu) then will automatically start playing the video (or last video) on the CD.
Please let me know as soon as possible.![]()
I think your menu problem is a powerDVD thing, I know winDVD has more support for (S)VCD Menu's. Those things relate to the CD-i support, I don't know if you can do without them, but unless your using a CD-i (and who is??) I think you can get away without having them. They don't take up much space though.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
