Results 1 to 23 of 23
  1. when i go to Run and then type in MSCONFIG
    i can disable or enable startup items......is there a way that i can order the startup items and load some before others.............
  2. I don't think you can change startup order via a registry change or 3rd party utility, but you could probably create a BATCH file with the program command lines in the order you desire and create a PIF or shortcut to that batch file in the STARTUP group to execute on Windows startup.
    Never tried it -- just a thought !!!
  3. anything else guys..........it is not like i want my programs............but i have norton internet secuity and and windows washer and system mechanic and anti virusees and in the msconfig norton has like 5 different things. and that slows up my boot up........if there was a way i can load the norton items first or last...................anyother ideas............
  4. Banned
    Sep 2004
    Inner Circle of Thought
    You do not need windows washer or system mechanic starting up at bootup at all.
    If you disable those two you will find it improves your startup speed.
    I have a question?
    Why are you using a separate antivirus and internet security?
    That is another problem.
    Internet security has an antivirus program in it.
  5. that is what i meant........it is just there are two seperate icons that is why........
    this is what i have done......i have enabled the firewall on my router.........and uninstalled norton internet security leaving only the antivirus.................
    so now i have new programs
    norton antivirus 2004
    system mechanic 5
    cybersitter v9
    windows washer
    and that is it.......that is the only thing that i booting up and it is much much faster now...................
    another question for the system mecahnic what is the optimized settings for the cleanups and how oftem should it be done
  6. Banned
    Sep 2004
    Like I said earlier, system mecahnic and windows washer are not needed at bootup.
    You could turn those off and only run them when you need them.
    You should maintain your computer about once a week.
    You really don't even need windows washer. I have seen it mess up many systems.
    Jul 2002
    Up in yo' bitch.
    My two cents... ditch anything that is made by Norton...
  8. smearbrick1 - you keep telling us to ditch norton.....what do you use.......
    http://www.aaa-a1taxiandtours.com/
    niagara falls buffalo new york ny
    Jul 2002
    Up in yo' bitch.
    Mcafee... I have had several issues with both Norton 2003 and 2004 (antivirus) and the Norton Utilities package. I have also read several user's complaints concerning issues after installing Norton products. Just do a search in this forum alone. Also, in my experience, it appears that Norton is a bit of a resource hog.
  10. Banned
    Sep 2004
    I have used both Mcaffe and Norton but prefer Norton/Symantec.
  11. thanks guys for you imput.......
    now for all of you......who dont use norton or mcafee and use other virus programs......please tell us what you use and why you use it.....and if you answer is avg dont say because it is free......we want to know about programs that you actually have to pay for......
  12. Banned
    Sep 2004
    Pcmagazine just rated Norton #1 in it's November 30th issue.
  13. Originally Posted by bazooka
    I prefer McAfee Corp version (4.5) over everything that I have tried.
    BTW, I did install the latest home version of McAfee but promptly got rid of it do being a resource hog just like Symantec. The only thing I use by Symantec is Ghost and that's only the command line version.
    Originally Posted by jagabo
    Jul 2002
    Up in yo' bitch.
    Who is "we"?
  15. "we" refers to videhelp.com users.........and other people like me who where need of help but were busy and couldnt post their questions!
  16. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    And why do you want to only know about ones you have to pay for? Just because it costs money doesn't make it good. AVG is a highly recommended app, BTW I use Mcafee.
  17. i just think that it gives them the desire to make better programs..........
    you are so funny.........first this has nothing to do with it..............
    and then, if AVG (free edition) is highly rated.........lol.......then why do you use McAfee
  18. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I use Mcafee because it came with my comp with a years subscription, and to tell you the truth your the one that is funny since you obviously have no clue. Anyone who would install something such as Windows Washer..... well, I'll leave it at that.
  19. you such an idiot.......the reason why people post questions on message boards.....is because they dont know.........an i am man enough to say i dont know everything about computers........that is why i am posting.....if you have a problem with people who are not computer gods......then i suggest you stop replying to posts then................
    if you dont have anything productive to say.....dont say anything at all....
  20. Banned
    Sep 2004
    You should definitely get rid of windows washer.
    I have seen it mess up several windows installs.
  21. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    It's "You're such an idiot."
    Correct, you asked about virus protection but your post shows your lack of knowledge. My answer was to provide you with some. Your reply was to call me funny.
    Being an idiot it's sometimes hard for me but I do all the time. Fortunately most posters are grateful for my advice or bits of wisdom. If they were all like you................
    BTW, the best virus protection you can get is the person between the keyboard and the mouse. That's probably not an option for you, It's free though.
  22. irrelevant and not nessesary
  23. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Then why did you ask? It was your question not mine. Perhaps you should consider not asking irrelevant and unnecessary questions.
