Does anyone know of a good Spanish language forum for an Argentinian friend who wants to buy a dvd recorder? Apparently no one is able to give him any decent information.
Thanks.
Do a forum search. I've posted links in the past. There are at least 1-2 forums last I checked.
I have already tried a search using various combinations and I did not get anything.
Therefore I repeat the question.
Thankyou. -
Did you check out Doom9? They have multiple languages there:
http://spanish.doom9.org/
Try es.rec.video.dvd, it's on Google groups. Not very active, but you will find helpful people there.
Guifre -
I cannot find my old posts either. Odd.
I should bookmark these:
http://dvdadvdr.com/forums/index.php?s=
http://www.forodivx.com/
http://www.portaldvdr.com/exoops/modules/newbb_plus/index.php
http://www.peque.org/foros/index.php?sid=07c94ecf1e19c7f810afd41a5632024b
Also use www.google.es and "páginas en español" to avoid other languages.
"foro" is forum. And "video" is video.
Looks like http://www.dvdrspain.com is either gone, or you need a ES proxy.
And of course, you'll need to know Spanish.
De nada
How to remove spanish audio?
By skorpinok in forum Video ConversionReplies: 1Last Post: 6th Jan 2012, 10:06 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Getting spanish only.
By Fiostech in forum Blu-ray RippingReplies: 2Last Post: 3rd Feb 2009, 19:54 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29
