Having trouble with the newest version of NVE (yes, I upgraded from an "honest" copy). After completing my menus I try to then render the project. Whether I choose to burn an image or just to a dvd folder NVE hangs about 10 minutes into "Creating menus and transcoding streams." I've rebooted and retried several times with the same results.
My source files are a bunch of mpg files I've transferred to my PC after burning them to dvd from a Panasonic DMR-E85H standalone recorder. I load them all into the project then merge them to one title for ease of adding chapters (they're the World Series games, and it's easier to add inning chapters if you merge them all first). Adding the chapters and making the menus all went well. Any tips? Thanks.
I've had NVE hang on me under several different scenarios, but not specifically when using MPG files made externally. However, I have found the easiest way to kick-start it is to use the Make Movie function. I use it to export a movie and then feed that into the Make DVD function. It's kludgy, but it usually works.
In extreme cases when I'm transcoding AVIs to MPGs, I've had to recode the AVI into another compression format (Huffyuv lossless) and then let the Make Movie function take over from there. If you can't get the MPG files to cooperate, you might want to consider this as an absolute last resort.
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
