I recorded something from my TV tuner in mpeg-2 format. For some reason, the volume is very low. Is there anything, preferably freeware, that will allow me to edit the file to raise the volume level?
Hello,
You could use tmpgenc to split the sound out - file - mpeg tools - demultiplex.
It will let you save the audio as a mp2. There you could either use besweet gui to convert it to wave and use soundforge or audacity or another audio editor to boost the sound. Or some other audio program may accept mp2 without converting.
Then you can load the boosted sound file back into tmpgenc. Go to file - mpeg tools - multiplex and load the mpg video and the new audio to make a complete file (be sure to use program stream since your end result you want is dvd and not svcd)
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Avisynth. Stumbled audion while Dissolve()
By egochnpp in forum EditingReplies: 4Last Post: 4th Feb 2012, 07:26 -
Increase sound level of a m4v file
By Neil Crumpen in forum EditingReplies: 1Last Post: 19th Oct 2010, 03:14 -
Level Of MPEG in Conversion Process
By dbborders in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 21st Sep 2009, 10:55 -
Encoding matroska file to AVC level 3
By flash74 in forum ffmpegX general discussionReplies: 2Last Post: 11th Feb 2008, 11:04 -
Double audion when converting AVI to MP4
By avni in forum MacReplies: 0Last Post: 12th May 2007, 23:29
