Forum Index -> Other -> Test Printer-friendly version
Reply to topic
Author Message
yoda313
Jedi Master
PostPosted: Nov 06, 04 01:29 View users profile Send private message Reply with quote Edit/Delete this post Delete this post View IP of poster
[color=Dark Blue]You are a STAR WARS freak, you are hearby sentenced to be laughed at relentlessly by your peers, but the force is with you, live long and prosper -moderator tgpo[/color]
_________________
You are a STAR WARS freak, you are hearby sentenced to be laughed at relentlessly by your peers, but the force is with you, live long and prosper /MODERATOR TGPO
Report this post
yoda313
Jedi Master
PostPosted: Nov 06, 04 01:32 View users profile Send private message Reply with quote Edit/Delete this post Delete this post View IP of poster
You are a STAR WARS freak, you are hearby sentenced to be laughed at relentlessly by your peers, but the force is with you, live long and prosper /moderator tgpo
_________________
Report this post
bazooka
Explosive
Warnings : 1
PostPosted: Nov 06, 04 01:40 View users profile Send private message Reply with quote Edit/Delete this post Delete this post View IP of poster
You need to make it smaller to make it look more legit.
_________________
You are a slacker and are hereby sentenced to a lifetime of burning CMC discs.
/Moderator Capmaster
Report this post
tgpo
Coming Soon
PostPosted: Nov 06, 04 05:55 View users profile Send private message Reply with quote Edit/Delete this post Delete this post View IP of poster
tgpo is lowercase, just to make it look more legit
_________________
https://www.videohelp.com/~tgpo
Report this post
Display posts from previous:
Reply to topic
Results 1 to 1 of 1
