ok converted some xvid files to mpeg2 with winavi then when i try 'add file' with tmpgenc dvdauthor it says:
the video bitrate 4294267 kbps is too high for a standard dvd, the maximum rate is 9800 kbps blah blah.
How do i fix this?![]()
Results 1 to 10 of 10
TDA only looks at the header, not the actual mpeg stream. Often the header is wrong (too high) so the warning can be ignored. If you want to be sure, check the mpeg with bitrate viewer to see the true bitrate.
ok it said the peak bitrate was 4158 & average 2130, so i guess this means i can ignore the warning then? i read the msg can be ignored but then i thought it might not play on all players, my 3 yr old pioneer pretty much plays anything i throw at it but i want to make some dvds for friends so want to be sure it will play on their machines too.
hmm ok now after i click ignore the error it comes up with 'an error has occured in the mpeg video decoder' , would this be because its a partial file? i only encoded part of it with winavi to test it out.
It might be that, or it might be something else.Originally Posted by chooklotto
Try cutting a small section out of your source avi and encoding that and see if TDA accepts it. -
ok i encoded the whole file & tried it with the same error occurring, what should i try now?
Never used winavi myslef so I don't know what it does/can do.
Maybe try a different encoder.
Maybe scan the source file for errors.
search the forum/tools section for mpeg fixers -
what other tools did you use though? i used winavi to encode. Maybe its something to do with the codecs, can you tell me which you have installed?
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
TMPGEnc Authoring Works - bitrate too high
By ecc in forum Authoring (DVD)Replies: 9Last Post: 19th Feb 2009, 13:06 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 11:16 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 17:01 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42
