I have downloaded a film from the internet, ran it through
AVI2VCD program then went through Nero 5, but the disk is not recognised.I KNOW I HAVE DONE SOMETHING WRONG BUT I DONT KNOW WHAT.
Pete.
Are you playin it on a Computer or DVD player ....if DVD player standalone maybe your player doesnt support CDRs..if you are trying to watch it with a DVD Player Standalone go ceck the DVD Players list on the side and see if youe DVD Player is there and if it supports CDRs
Film plays ok on PC. But not on stand alone DVD player or playstation 2. It does not auto play on PC I have to open it up.
My DVD player is Bush 2009 which is not mentioned in compatibility list. In the handbook it says disks supported are VCD, and CD-DA what ever that is. -
but the did it say compatible with CDRs the the keywords here is compatible with CDRs and o yea PS2 doesnt play VCD atall and and on your computer go set it to autoplay
When I put the disk in to my drive on PC, it opens up with 5 folders, [cdi, ext, mpegav, segment, vcd,] it does not play straight into film,to get to the film I have to open mpegav, then open the file inside called AVSEQ01.
If you want to autoplay a VCD, you will need a specific program to identify it and load it, something like Creative Disc Detector, or PowerDVD, or WinDVD, basicly a program that KNOWS there is a VCD in the drive.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
DivXLand, what wrong???
By kei_siuip in forum SubtitleReplies: 2Last Post: 7th Apr 2011, 00:14 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Somethig Wrong!!!
By SIRCOOKS in forum ComputerReplies: 11Last Post: 7th Feb 2008, 15:03 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
