    Nov 2004
    Durham, NC USA
    Hey there,
    Just did my first "real" capture. Looks good, but my audio settings were off (input level was set way too high.) Clipping all over, too loud. What can I do? I have Sound Forge 7 w/ Noise Reduction & MPEG 1&2 plug-ins, the file is MPEG-1 . Thanks in advance...
    - John
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Best option is to re-capture if that is possible.
    Otherwise try the normalize function and for the option entitled, "If clipping occurs" try selecting, "apply dynamic compression"
    That might help.
    - John "FulciLives" Coleman
  3. You can't really do anything about it, it's damaged, you can't undo it, at best you can reduce how noticeable it is, but probably not. Recapturing is the only way to fix this.
    Apr 2004
    Miskatonic U
    You could also try smooth/enhance under the Process menu. Ultimately though, it is like trying to fix a photograph taken with your thumb in front of the lens. You have to rebuild whats missing, or crop it out.
    Read my blog here.
    Nov 2004
    Durham, NC USA
    Thanks all... have found the "Recording Volume" adjustment for future attempts. Can't recap this on etho... was capping TV and have to wait for (eventual) rebroadcast. Turns out I capped at the wrong resolution as well... what should I use to re-encode the video to the proper dimensions?
    8< [] Rock is dead! Long live Paper and Scissors!! [] >8
