Ok, so I've been using Nero 6.3 to burn all my DVD ISOs and sure enough, I decided to upgrade to 6.6 and it's not working, it's doing all kinds of crap when I go to burn such as ejecting the dvd, then closing again by itself, then it sits there and reads the disc and finally the burn fails, nothing written - any ideas? any better programs?
use dvd decrypter to burn ISO images or IMG TOOL BURN. try uninstalling NERO 6.6 then use the NERO CLEAN TOOL then reinstall NERO BURN.
hmm what is nero clean tool?? and those other programs you mentioned, are they good quality? I'm burning DVD masters to send off for replication, I need good burns, this isn't for home rec use...
dvd decrypter you can find in the tools section of this forum site. it's a free software to use.
here's a link for the NERO CLEAN TOOL.
http://www.nero.com/us/631940828445001.html
here's the link for IMG TOOL BURN.
http://www.coujo.de/ib/index.php?s=41b934ccd2eac88552827cc0929018c9&act=html_include&incl_
this is a free software to use as well. as long as you have NERO BURN installed on your pc you can use IMG TOOL BURN. It doesn't do ISO images but it's a good program to use to burn dvds.
Try out the software if you don't like it then use another program.I need good burns, this isn't for home rec use...
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53 -
trouble withe using nero 4
By jc2823 in forum Latest Video NewsReplies: 1Last Post: 30th Aug 2010, 12:54 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Nero burning trouble with logs.
By bufalo in forum Authoring (DVD)Replies: 4Last Post: 13th Jan 2008, 08:43 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10
