Hi!!!
I´ve the following problem with it:
by opening the program it shows me a message that I´m only be able to encoding MPEG2 for 30 days.
I thaught it´s freeware! Who can help me?
Thanks HAI
Results 1 to 9 of 9
Although the PROGRAM itself is free, the MPEG2 encoding codec isn't. Royalities must be paid. Hence a 30 day trial.
Look around there are ways.............i.e do a search of this problem you will find an answer -
Check out the following posting.
https://www.videohelp.com/phpBB/viewtopic.php?topic=66621&forum=3
Regards,
Ronin2 -
open notepad
copy and paste:
REGEDIT4
; Enables TMPGEnc's MPEG-2 encoder for 30 more days.
[-HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}]
then save as (use the copy and paste function here too, with the quotes )
"TMPGEnc_MPEG2_Reset.reg"
this will create a registry key
save it in your desktop documents folder and double click about once a week and your mpeg2 period is extended
I found this on the TMPGEnc support page:
Here is my solution to the MPEG2 30day limit on TMPGenc:-
When it is first run, on both my computers, TMPGenc creates a key in the registry under: HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\ called {63902277-B101-4049-8B46-C24B67E155E5}. If this key is not present TMPGenc assumes it has not run before and gives you 30 days.
To delete this key I therefore created a Regedit file, using notepad, called it TMPGreset.reg and saved it in the TMPGenc directory which on my computer is on C: drive in C:\Program Files\TMPGenc.
This is the contents of the Regedit file:-
REGEDIT4
[-HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{6390227 7-B101-4049-8B46-C24B67E155E5}]
Next I created a batch file to first execute the regedit file and then to start TMPGenc. This then resets the date everytime I run TMPGenc. Again I used notepad, called the file TMPGenc.bat and saved it in the same directory. Obviously if your directory is not in the same place you need to ammend the text accordingly.
This is the contents of the batch file:-
regedit /s "c:\Program Files\tmpgenc\tmpgreset.reg"
"c:\program files\tmpgenc\tmpgenc.exe"
Next using explorer I right clicked on the batch file, selected properties, selected the program tab and selected Run minimised and Close on exit. Then I selected change icon, browse, navigated to the TMPGenc directory and double clicked on TMPGenc.exe then selected OK. this changes the Icon for the batch file to the same as the TMPGenc icon. I then placed a shortcut to the batch file on my desktop and I use this to open the program.
...courtesy of ken.hanley@virgin.net
This works like a charm and is ingenious! -
Yes!!!
It works but for how long? Oh well I'll wait for another 30 days to see if it really does work..
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
