  1. I have video that I have caputered using SONY Micro DV (model IP1). I wanted record this video onto DVD. I captured this movie to my PC using "Sonic My DVD" software that came with my PC. I used USB to trasfer the movie from Micro DV to computer. When I did preview of what I caputered there is no audio. It caputred only Video. I seleted the option in Sonic My DVD to capture the audio also.
    What should I do to capture the audio also along with video.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    You shouldn't need to "capture" the video at all. The camera already captured it.
    All you need to do is transfer the file. No need to use a Fisher Price all-in-one app like MyDVD. You need an authoring app to get it to DVD, not MyDVD.
    Look through the tools section here. There are plenty of free authoring apps that can take the AVI DV file your camera sends and convert it to burnable DVD files. Then use something like Nero to burn. Easy
  3. pvarakantam,
    The only useful suggestion I can offer is to try using the firewire link instead of USB. I have the IP55 and always transfer to PC with the firewire link and do not have problems with the audio.
