  1. Currently have Firmware 2.16
    Now I see the majority of media is 8x. Can I use this media in my drive although it is only a 4x burner
    Cheers
    Kwack
  2. Member 888888's Avatar
    Jan 2004
    Turdistan
    Cheers
    Kwack
    Yes. Please check this list to see if Accesstek (Optorite) officially endorses a media as compatible.
    http://www.accesstek.com.tw/_english/2_product/02_spec.php?hID=5
    Note that media will still only burn at 4x even if it is rated 8x. I don't believe there are any Optorite hacked firmwares that let you raise the speed, and frankly I don't care.
