i want to convert an avi file to mpeg2. i want to play it on my motorola
e398 mobile phone.
i copied the video details from one of the files already on my phone:
Header found at: 22816 bytes
Length: 12 seconds
MPEG 2.0 layer 1
112kbit, 503 frames
24000Hz 2 Channel
CRCs: Yes
Copyrighted: Yes
Original: Yes
Emphasis: 50/15 microsec
i figure, i would probably have to create a video file with the same details.
can you recommend a tool?
thanks
How can I convert a mpeg2 and ac3 file set into a mp4?
By woppyvac in forum Newbie / General discussionsReplies: 10Last Post: 5th Apr 2012, 09:01 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Batch convert DV-AVI to MPEG2
By w@ntonsoup in forum Video ConversionReplies: 3Last Post: 27th Sep 2009, 16:08 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
i'm trying to convert a mpeg2 file to an mp4-audio is out of sync!
By cduval04 in forum Video ConversionReplies: 1Last Post: 22nd Oct 2007, 17:56
