Hello all,
I've had the surprise today to notice that i received new Ritek medias instead of the usual G04 i'm used to order. The media code is RITEKM02. So i've searched on the forum and found out that the G04 are discountinued !![]()
I've always used those for their excellent compatibility on DVD home players and i've been very happy with them. What's the point with the M02 ? Are they better ? If yes, what's the differences ? Does anybody have any experience with them and know about their compatibility ?
I wonder about my futur orders![]()
Thank you.
EDIT : Alright, it seems now that the M02 are crap. So what is the best dye for DVD player compatibility ?
Results 1 to 15 of 15
i have heard some bad stories about M02 media but i have burned 50 dvd-r's so far and had no problems so far
Latest newsletter from UkDvdr had some info on the new M02 dye and links to info on it... Did'nt make for good reading.
Not bothered by small problems...
Spend a night alone with a mosquito -
If you go to UkDvdr you can subscride to their newsletter...
I have no views on what is posted in this letter as i have not used any of the new Ritek M02 Dye. I have been happy with the G04 dye and seem to have no problems with the G05 dye either...From UkDvdr Newsletter 4-11-04
What Happened to Ritek DVD-R Quality???
Its crap and what are we doing about it???
FACT
Recently it has been highlighted on many forums and discussion groups that the quality of discs produced by certain manufacturers has gone down hill. Click here for some examples.
To further compound the problem, Ritek, who previously set the standards for 4x DVD-R have now started using an inferior dye in many of their discs - the Ritek M02 dye. Our customers have been buying discs assuming they where G04 and inside the pack is an inferior M02 mixed in!!
As a result many of the major brands have switched over to other dyes. The disc that has totally blown everyone away is the new Datawrite Printable 8X. This disc is manufactured for Datawrite by CMC magnetics using a Mitsubishi Dye (same dye as verbatim and TDK).Not bothered by small problems...
Thanks.
Well i think i'll just drop the Ritek disks then
What's the most compatible (for DVD home players) dye after the G04 ? The TYG01 ?
I like the sony media that comp usa carries ,they seem to have always worked for me and they are on sale just about 1 time a month.
In the chain of "what works best" in terms of readbility, Ritek is actually mid to low on the totem pole. TY and MCC (and several other AZOs) are better.
Yeah, i've read many times in the forums that they were very good. But my first interest is the compatibility on DVD standalone players. As far as i know, the G04 were the best for that. So i'm wondering which dye could be an alternative. What about the G05 by the way ?Originally Posted by lordsmurf
I've been using Prodisc S03 and haven't had a problem yet. Doing video transfers of the little one to send to grandparents, aunts, uncles etc, etc. Have approximately 20 different dvd types (Both standalone and PC DVD Roms) and no complaints about non-playability yet. In fact my mom's player would not play the G04 disks that I used to use, sent her a prodisc and it plays just fine.
A good playback test is to run a DVD at 8x FF and see if it sticks or plays. RITEK, more often than not, will stick. Cyanine based discs, same story. The better organics and AZOs, generally do not freeze.
That's a test I run.Want my help? Ask here! (not via PM!)
I know that TY is the best media quality around but i'm still not convinced about the compatibility on DVD standalone players. And i don't know even know about the console (Xbox, PS2 ...) one.
I burn some films for my clients who distribute to several people, that's why the media must be played on almost every DVD players, like the G04. With them, i've *never* had any bad return in one year. Does anybody have a good experience into "DVD distribution" using with the TYG01 or TYG02 ?
Thank you. -
BJ_M has gone through tens of thousands of them.Originally Posted by Lucius SnowWant my help? Ask here! (not via PM!)
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 16:42 -
Question: DVD, CD or ROM DYE LIFE
By mjk4ty in forum MediaReplies: 1Last Post: 10th Feb 2008, 20:18 -
Color of dye on disks
By jbartosh in forum MediaReplies: 3Last Post: 25th Nov 2007, 18:15 -
Different dye coloration after burn (TDK DVD)
By xSimonx in forum MediaReplies: 2Last Post: 24th Sep 2007, 21:29 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 16:45
