  1. I am trying to back up a movie from a dvd to a dvd+rw. I have a program that will copy it directly to a dvd. Have used this program before backing up whole movies to one dvd. The problem started when I bought a dvd+rw. I didn't know that the rewritable dvd's need to be formatted before use... now I know.
    The program I use ( don't know if I can mention it here) does not format a DVD+RW... everytime I try to use the dvd I get an error message saying it is formatting then I get a box that pops up and says "error". I have to shut down the program ans start over but I keep getting to the same problem.
    I have window's xp with a sony dvd rw dw-u12a.
    Is there a program that lets you format a rewritable dvd ????
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    NERO BURN or any other burning software.
  3. Hello
    I can make a copy of my original DVD film with: AnyDVD + CloneDVD2
    Yes .. to a DVD +R
