I am using the process outlined here to convert my audio source from PAL to NTSC. I am having issues with using the Besweet GUI 0.7. The problem I am having is I can't pick a .wav format for the input file. Its looking for an .lst file. I also can't get Wav to Wav box located on the bottom left (check link). I get LST to Wav. Can someone explain this to me?
Next I figured a way around the GUI by using the "Copy Command to clipboard" and then editing and running it. The command is
C:\program files\besweet\besweet.exe -core( -input "D:\test.wav" -ouput "d:\newtest.wav" -2ch) -ota( -r 25000 23976) -profile(~~~~~ Default Profile~~~~~)
The problem is when I get to the VirtualDub portion I get an error something like the wav is invalid or not proper. Something like that. Any ideas?
In the select input box did you click on the drop down arrow to change the extension to wav?
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55 -
Fieldblended PAL->NTSC issues
By dansrfe in forum RestorationReplies: 10Last Post: 12th Dec 2009, 02:28 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06 -
Argh! More converting PAL to NTSC!
By Nilfennasion in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2007, 20:56
